HangOutdoors
- Royal Oak, MI
I just did my 10 hour oil change. I siphoned out about 3.125 quarts from each engine. I put back in exactly 3 quarts so I could check the oil on the lake today when I know I would be perfectly level. The oil on both engines was midway between F and L.
Today on the lake, I noticed I was running WOT at 7100-7200 rpm and I was not getting over 35 mph. Before I was hitting 7500-7600 rpm and I hit just under 43 mph. I ran for a couple of hours and then I checked the oil while in a calm patch of water in a cove. Same thing. Half way between F and L.
I used the Yamaha Engine Oil Kits from my dealer. I purchased 2 when I picked up the boat.
What could be going on? I didn't do anything else to the engines but oil change and filter.
