mark_m
- Columbus, OH
- SX
Bruce, I had two that I had to twist off the head with an easy out. Once done I went after the stud with a vice grip. It was not an easy endeavor, i shot all of the day last Sunday getting that hatch off.Only one bolt was an issue?
I ended up drilling three of mine out. https://jetboaters.net/threads/my-experience-removing-the-fuel-tank-access-hatch-to-add-sound-insulation.6309/
For a bolt in a similar postition to yours I simply drilled a 9/32" hole where it had been and re threaded it with a new 5/16" bolt.
Yes. I wanted the access to run the wires for the port side speakers to the helm and for the power and ground wires to the amp in the helm.@mark_m I just found your install thread - it looks awesome!
Are you messing with the fuel hatch just to run wires?
I agree with what's been said. Going around the bow is another good route.Yes. I wanted the access to run the wires for the port side speakers to the helm and for the power and ground wires to the amp in the helm.
If anyone has alternate suggestion on how to get to the helm easily for the port side speakers I'm all ears.
I started with 80hz and played around with the input sensitivity by ear until I "heard" the sub overpower the coaxials and backed it down until it blended in.Power runs were wrapped up Sunday and a very brief input sensitivity session, was all set for the water Monday.
The JL 650s amplified sound awesome, with the transoms only there was plenty of oomph to keep the party going while we hung out back on the gang plank.
I need to set the crossover frequencies yet- is 80 hz the appropriate cutover with the sub?
Love it! I agree on the fine tuning bit, I have a bit more work to do there. I used crude technique with YouTube and Bluetooth connectivity to get the 50hz, 1khz tones. I think they are available for download direct from jlaudio site and I think I'm gonna redo using transfer to usb stick and try that way.@mark_m how are you liking your stereo? I'm mostly finished with mine, but need to do some fine tuning I believe to get the most out of the sub. Mine isn't that loud right now, so maybe I need to adjust gain up a bit.
I think the stick is the better way because you have the phone driving the volume of the test tone and I don't remember what level I used on the phone itself.I'm running 8 mx650's off the m800 amp, and 1 m10ib5 sub off of a m200 amp bridged. I also tuned using the 1khz and 50hz test tracks from JL audio's website via Bluetooth from my phone. Starting to wonder if that's the best way, or saving the files to a usb stick like you mentioned. I have sub amp set on low pass and around 120hz. The other amp running the main speakers is set to high pass and at 80hz. I'm sure I need to change that setting, but haven't got around to it. I will say that I turned the loudness feature of my head unit on and it made the sub louder. Still think I need to adjust something because I feel like the other speakers are overpowering the sub. I have a wet sounds ws420 that I need to install so will probably wait until I have it in to adjust anything else.
