VitaminSea
- Central FL
- SX
That can be normal. I believe there is a video on here that showed as you come off plane, your wake can push water up through the clean out tray drain. Some have installed a check valve here.
You mentioned earlier, you cruised around for 5 minutes. Was that all on plane, or coming off plane and back a few times?
