Rod5
- Marietta GA
- 255XD
I'm also in for a cockpit kit, and few additional mats. Just emailed Will...
I think the snap down versions would be the ultimate with seadek. Yamaha has put these in some of the 2017. It is a nice feature to be able to remove the seadek & store for a much longer life. Plus you still have the options of 2 floorings on board for fishing. Not having to remove the snaps & filling in holes with 5200 makes for a much better setup.
YouThe huge downside is that you need to remove it to let it dry and clean out debris which is the same problem we have with carpet.
With glued down SeaDek you just hose it off and go. Fish blood and guts hose right off of it. That is why it is used on so many fishing boats.
But if it snaps down all kinds of nasty stuff will get caught underneath.
Yeah your right Bruce. I changed my mind & am getting some seadekThe huge downside is that you need to remove it to let it dry and clean out debris which is the same problem we have with carpet.
I'm sure you can add some pieces when Will contacts us at the end of the month. I'm thinking about adding a couple more pieces as well.Can I edit my order or do I need to make a separate new one? I'm thinking about adding a bow kit.
