Welcome to Jetboaters.net!
@jcyamaharider man I wonder how much vibration your going to get in your throttles and dash with the sub mounted there. Mine is behind the drivers seat in a sealed (.875) box and I get a little vibration now in the throttles, its not much though.
I did the same, that carbide tip cut it like butter in one pass.
I used PVC board board from Home Depot as a baffle on the backside. That space would really suck to get to though, I was able to reach around from the storage area and battery compartment to get it bolted on.
Nice work on the hole.That is where my current hole is. I moved the harness up ( had to extend the lanyard switch and neutral wires) and stuffed closed cell foam all around already. As mentioned in another thread I am using spray foam and glassing over it to create a box in there for my polk 1040 mm. Same on the other side of the boat too. I have a long weekends of mods planned this weeknd and next and hopefully will be done before April.
I do recommend the closed cell foam stuffed between the throttles and hull along with the upper cavity as well to reduce vibrations. I also made beefy speaker rings out of starboard to stiffen it up and recommend those as well. I am sure it will sound great when you are done.
I agree with @Mainah with some kind of insulation like the cell foam to minimize vibration. It seems the gunwale in our boats are thin and vibrations are inevitable at times. I had to re-position my subs to face the cabin vs the gunwale because of this. Please keep me posted on how everything goes so I can plan future projects. Thanks for the great info and pics. You know me, I need pics with my simple brain.
I think today is my first day on the water to test out my new setup. 80 degrees today. I'm PUMPED!
I finally got around to rewiring to free up the soundbar and I have to agree with @jcyamaharider that "holy crap" it is loud.
I decided not to cut into my harness though to separate the soundbar. Since I was going to have to run wire anyway to the rear cabin speakers, I just removed the terminal connectors from the rear cabin speakers, and soldered those wires together to close the loop for the soundbar. Then ran new wire altogether to hook up the rear cabins to the other amp.
