2021 252 FSH lift bunks???
CA3SAR
I’m picking up a 2021 252 fish this week. I have 8 inch bunks on my lift and I do not know the spacing in the front and rear. Does anyone have the measurements for this boat thanks in advance.
Hope this helps.
On my trailer: They appear to be 24 in apart in the front of the trailer, and 36 in apart on the back.
The final picture is around 37" to 43" from the center.
Hard to take pictures while holding a tape measure and raining!
I just received my boat and was wondering if you figured it out as I may have a similar set up on my lift. The boat will not clear the boat lift beams using the trailer bunk distances from center. I must go closer or install taller bunks. What did you come up with?
My tear is like 29” and front is around 22”. I align my tank cap with the rear beam for my setup. Let me know if you need more.
Thanks for responding. How much clearance does this give you from the keel to the boat lift beam? Is your transducer clear of the bunk?
If I had to guess 2-3”. It’s the safest approach I feel
Thank's I just used your dimensions with a true 7" vertical set of bunks and I have about 2" of clearance over my I Beams.
