HangOutdoors
- Royal Oak, MI
No worries, enjoy your boat and your time with your daughter.
It’s not just top speed, if I want to cruise at 40 I don’t want to be WOT, nor do I want to be at 7k RPMs to go 35. So to me top end speed matters even if I don’t plan on going that fast all the time. Plus ounce you start adding more weight and maybe you have a couple nicks in your impellers that 43MPH top speed is now low 30s at WOT. Or maybe you boat at higher elevations so again that 43 top speed is now reduced to being in the 30s at WOT. Plus as engines get older they can start to lose performance too.Would like to take anyone out on a boat and see if they can tell me if we are going 45 or 50...
@Ian S ....yes the supercharged 1.8s will do it. You'll have an arm pulling rocket! MY SX 195 will smoke, in acceleration and match the top end (51.2 MPH on GPS) of a friend's bowrider with a Mercruiser 350 mag in it.OUCH... That's too slow... It's the same issue w the 2020 and older 210's w the twin 1.0L's.... 42.3 MPH w ideal conditions... translates to a slug on the water, especially when you are loaded up for the day. I guess I am now in the "boat" of stepping all the way up to the 255 and the 1.8L super charged motors. I saw that they were hitting 54 mph... that's a big difference for me.
That makes no sense with what boattest is showing. Their saying at 5000 you should be around 16.7 Like everyone else is saying I don’t think boattest is reliable. Thanks for sharing!Just had my new AR250 on the water today. 80 degrees, 90% humidity, smooth lake, 3 adults ranging from 120-170 lbs and 4 kids with full fuel. Cruises at 28-32 mph at 4500-5000 rpm.
@KCAR250 I think they just simply plugged in the wrong numbers for the review, or it seems the curve for acceleration is from some sort of raw data rather than observation. I've seen several reviews that has mis-leading speed/rpm numbers.That makes no sense with what boattest is showing. Their saying at 5000 you should be around 16.7 Like everyone else is saying I don’t think boattest is reliable. Thanks for sharing!
@mwalker4 Boattest updates the years covered if the model doesn't change hull or engine configurations. That way they don't actually have to test another model year to get the same results - the 18 and 19 are the same boat just different colour schemes.Boattest tested a 2018 SX190 and thought they were testing a 2019, so I'm not sure about their attention to detail. This review has been on their site for 2 years. Yamaha SX190 (2019-) | BoatTEST
I’ll take the 5 extra gallons! I wonder if their tank supplier changed due to covid and the new tanks are now the 75gal.I noticed Yamaha on their website now says 75 gallons for the 25' footers. Interesting they slipped it in on their website. Unless I am mistaken I thought it was 70 gallons.
Also early next week I am hopefully going to look at a 252SE at my dealer. See what I see and see if it gets me closer to upgrading.
I’d be interested in you posting your opinions if the viewing works out ?I noticed Yamaha on their website now says 75 gallons for the 25' footers. Interesting they slipped it in on their website. Unless I am mistaken I thought it was 70 gallons.
Nope, 2019 SX190 is a completely different boat. Wider, longer, totally different hull. Has new instruments etc. Engines are the same. If I could go 43.2 mph in my 2019 in any conditions with no load I would do the jig.@mwalker4 Boattest updates the years covered if the model doesn't change hull or engine configurations. That way they don't actually have to test another model year to get the same results - the 18 and 19 are the same boat just different colour schemes.
As an example, if you look at the 2019 212 Limited S, the video is of the 2017 model and they simply updated it to include the 18 and 19 model years as it didn't change in water performance. They'll probably update it to 20 and 21 years at some point since the hull and engines have not changed. Yamaha tends to do hull changes around the 5yr mark, so in a couple years the 21ft models may get another major modification.
