Michael Night
- Florida
- 212SE
I seem to be in the minority when it comes to liking the rudder under the hull. I would think it's much more effective than the rudders that are behind the hull on the 21' & 24'. And with the draft of 15" for the 19' and 19-20" for the larger models, what's the problem? My hope is this rudder with make TV/Cobra fins unnecessary on my 2021 195S (coming soon!)New ride plate that extends further back that supposedly will help to plane faster:
Also metal drain plugs:
I was going by what's on the Yamaha website for each model.Draft is 17" on 21' and 20" 24', at least up to 2020.
I wonder what changed in the 24s because the specs on my 16 ar240 is 16.2 inch draft an almost 4 inch difference is a lot. Thought the hulls were the same from my15 to 20Draft is 17" on 21' and 20" 24', at least up to 2020.
We have no need for added fins on our 212s - it handles about the same as the old stern drive boats and I can dock it easier due to no gearing in the drive system (quick fwd/rev changes without issue).My hope is this rudder with make TV/Cobra fins unnecessary on my 2021 195S (coming soon!)
If you're in that shallow of water, you're already too shallow. Although the draft of jetboats gives more clearance, you have a vacuum cleaner under the hull that sucks up water and debris if you're in shallow water. Yamaha warns not to operate the boat in less than 3 feet of water for this reason. The rudder position becomes a none issue at 3 feet.just sitting in shallow water I’m always concerned with the rudder hitting the bottom.
Keep in mind this is while anchored or at a sand bar, not operating. Well anchored I always put the back the boat towards the shore, just not sure why it can't be even with the bottom of the hull. At the end of the day it just seems like an add on and not a great from the factory design. I always like floating into the sand bar then an I/O comes to try and get to the bar and they can't come even closeIf you're in that shallow of water, you're already too shallow. Although the draft of jetboats gives more clearance, you have a vacuum cleaner under the hull that sucks up water and debris if you're in shallow water. Yamaha warns not to operate the boat in less than 3 feet of water for this reason. The rudder position becomes a none issue at 3 feet.
When we launch the boat, we pull it down the dock to deeper water (3 feet or more) before starting the engines. Others think we're being nice to give them room to launch their boat right behind us, but it's more about us protecting the impellers.
I was curious and did some side by sides, and the A/K of the 19's hangs down because there is no centerline keel like on the 21's and above. Best guess is the 19's need the extra help from having part of the A/K section fixed in place just before the pump to help with centerline tracking, and the rudder part is attached there. The 21's have a long keel line and the rudder is placed just behind it. The 19's may need a little extra rudder help since they have one jetpump pushing as opposed to two. I'm sure Yamaha has done many hours in simulators and/or water flow tanks checking the A/K system and may improve it down the road, but it makes sense how they have it now.Keep in mind this is while anchored or at a sand bar, not operating. Well anchored I always put the back the boat towards the shore, just not sure why it can't be even with the bottom of the hull.
With commercial freighter vessels, I believe they list draft based on loaded and unloaded displacement for safe navigational purposes. For personal use, the amount of weight added probably doesn't make a significant difference, but since a smaller number is better, I'm sure they use unloaded for the draft numbers.Weight? I am not sure if that is considered in draft or not.
EDIT: I just looked it up and read an article and weight affects draft. So is draft a measurement when fully loaded or when no passengers and no gear are on? Does it include full gas tank? So in essence specified draft would be correlated to weight, and my 19" draft boat could be several if not more inches or lower in water at max passenger and weight capacity with full tank.
So I guess the question would be the draft in the specifications of our boats or any boats is based on empty boat or full boat with maximum carrying weight?
Could someone with some definitive knowledge on the topic chime in?
They cannot sell the 1.8 supercharged, it does not meet CA emission standards.I want to know something one of the dealers in cali said they dont sell 19’ and some 21’ because its not cali legal....thats bull crap thats not true the guy most be high or am i wrong
I get it, just saying I don’t like it. I think another reason is with a single they would almost have to make a deeper hull. As they probably don’t have the clearance below the pump coming out to do so. I do admit it is a big improvement over the old non articulating keel single engine. Just wish it didn’t hang below the hull. Not the end of the world but if I could change something it would be this.I was curious and did some side by sides, and the A/K of the 19's hangs down because there is no centerline keel like on the 21's and above. Best guess is the 19's need the extra help from having part of the A/K section fixed in place just before the pump to help with centerline tracking, and the rudder part is attached there. The 21's have a long keel line and the rudder is placed just behind it. The 19's may need a little extra rudder help since they have one jetpump pushing as opposed to two. I'm sure Yamaha has done many hours in simulators and/or water flow tanks checking the A/K system and may improve it down the road, but it makes sense how they have it now.
