21ft and 24ft transom ballast bags in stock!
We recommend and stock this size.
two question. One: how well does the 19 foot bag fit on the swim deck of a 24 foot AR? Two: what is this trick I keep hearing about, on how to move the swim deck ballast bag without deflating it or maybe partially deflating it? Thanks!
deflating was the wrong word. I meant draining or partially draining it.
Just getting into this sport and I was looking for some guidance. I have a 2017 AR 210
What would you recommend for ballast bags?
I was hoping to have them tucked away under the rear seats but I will take any suggestions
I would start with the custom bag for the back deck and see what you need from there. If anything additional is needed I would add a bag in the ski locker.
Never tried a 19 bag on the swim deck of a 24 footer but I can try tonight with air.
I am unaware of the trick to move the bag. I just use 2 pumps and it fills the bag in 5 minutes.
@jcyamaharider I’m interested in ordering bag for 242. I also PM’d you. Thanks!
Does it come with a pump? And all the fittings and everything I need?
Pumps are sold separately. Bags come with the fittings you need and a quick fill port for the tsunami pump we sell. The pump comes with the fittings to use with the bag.
21ft ballast bag for the swim deck still available? Also 375? Does it come with pump, bag, and fittings?
21ft bag is $400 plus shipping. Fatsac has the say so with the price and i am actually 10 bucks cheaper then their list. Pumps are sold separately. Bags come with the fittings you need and a quick fill port for the tsunami pump we sell. The pump comes with the fittings to use with the bag. Pumps are $165
What bag do you recommend for 2019 ar210 ski locker?
Not sure how big the locker is, if it will fit the 750 lb regular fatsac.
Did you ever decide on bags for your AR210? Getting ready to purchase and was wondering what worked for you. Thank you.
This is my current connection:
Identical intakes, pumps, and hoses as for the center locker 800lbs bag that fills in half the time, so it is worth considering:
did that pump for your 800lb locker ballast come with your boat or did you install yourself? If you did install, what kind of pump and was it difficult?
