HangOutdoors
- Royal Oak, MI
So I got my typical email from BoatTest.com today with a link to their review of the 2021 252SD.
Yamaha 252SD (2021-) | BoatTEST
It is a pretty sweet looking boat no doubt. Sitting at $82k ++
But, I was a bit surprised at the range and top speed of the boat, with minimal load on board. 43.8 MPH and 117 Miles on the range at full out. I would assume if you were loaded up it you would be hard pressed to crack 37-38 mph or so full out if you were lucky.
Very similar to the SX210/AR210 although the 252SD has a bit more range, especially in the sweet spot.
Yamaha SX210 (2019-) | BoatTEST
Then looking at the AR240, since I couldn't find the AR250 numbers, range is much closer but top end is 8-9mph.
Yamaha AR240 (2019-) | BoatTEST
I would like to see some real numbers of the AR250 with the 70 gallon tank. Has anyone came across them as of yet?
