1WetBoat
- Tampa
Here is a question for you guys that have done this. Is every intersecting section open between the front-rear tower tubes? So like where the welds are between the tower tubes?
I plan on running my VHF antenna but also want to prepare for future speaker mods on the tower. The antenna run will be simple so that isn't an issue, but I want to run and leave in place a lead that i can use in the future to pull wiring up. The lead is nylon so it wont rust or deteriorate. It's the one used for pulling low voltage cabling thru conduits etc..
My AR has a small plastic plug on the bottom of the front bar smack dab in the center of the tower so i could use that if needed.
