Hot2Go
- Iowa
- 252SE
Anchor locker fittingIt really looks great, where did you get that cover for the drain that’s on the outside? The chrome plated one.
Above is what I purchased, thanks to others who have replaced it already on here! It doesn’t quite fit in the hole so you have to make the hole bigger; whether that’s using a file, dremel, or in my case I used a drill bit (bcuz I have no dremel) and just slowly worked around the hole. No I didn’t drill new holes, I just let the friction do the work going around as the bit ate away the fiberglass. I then sealed all of the exposed fiberglass in the hole with 4200 before I fed the new fitting while using 4200 to seal up the rest of it too. It perfectly fits over the screw holes from the factory one, which you obviously seal those holes up as well!
