8in Speakers on AR190
jflamiat
AR195
My installer said he could based on measurements, but will plan to do so in May/June this year.
Farny
Spring TX
Centurion
Thanks - please post pics when done. I am considering the same.. gosh I am addicted to upgrades… already have 4 KTM8 towers 😵💫
jflamiat
AR195
So, sad news. The Kicker 45KM84L's do NOT fit in the bow of AR195. Thankfully did this before cutting any holes. While the depth is ok inside the hull, the grille does not allow the front seats to open/close. The surface area of the bow hull (height) is just not enough for the 8" Kickers to fit (it would overhang the top edge of the bow hull). Instead, I'll be keeping the stock bow speakers as is (going to wire them to be more like tweeters powered only by new Fusion head unit), and then put the 2 new 8's in the bow near the Port storage and Starboard bow floor (new holes to cut). Also, the rear stock speakers x2, new tower speakers x2 are all new 8" Kickers w LED, powered by 2 amps (1 to the 6 8" speakers, 1 to the subwoofer, and head unit to just the stock bow speakers).
Can send updated pics/review/specs if people are interested after the install is complete in about 2 weeks.
Johnboat
Texas
SX195
Anyone out there installed 8in speakers in place of the factory 6.5's on an AR190 model? I know the 8in should be an easy fit in the bow but not sure about the 8in in the factory locations in the rear.
Considering the kicker KM8 with the RGB grills....(I'm a sucker for lighting) Amazon.com: Kicker KM8 8-INCH (200mm) Marine Coaxial Speakerswith 1" tweeters,LED Charcoal and White Grilles,4-OHM: Car Electronics
If these will fit, 4 of these and a 12" free air kicker sub Amazon.com: KICKER KMF122 12" Marine Subwoofer with LED White Grill 2 Ohm for Free Air Applications: Electronics
Other speaker brands I'm looking at/considering are: Infiniti, Memphis Audio, JBL Stadium
Undecided on amp, class D (considering rockwell for the price) and will put in a fusion head unit later to integrate with my Garmin GPS via Fusion Link.
Thoughts/Critiques/lessons learned?
Just a suggestion, think about adding the 8"s mid ship. The sound will be much better and balanced. I added the same KM8 with 150W RMS mid ship and they rock hard.
