- Royal, AR
- SX
This is motivated by predicting Bimini crossing fuel consumption but should be of interest to all boaters as it includes maximum range for lake conditions as well.
I started with the BoatTest.com fuel consumption numbers. In the past I have looked at these based on RPM but RPM does not translate well across different engines. So I decided to interpolate range values for fifteen models of boats every six MPH from 12 to 48 MPH. I simplified the process by limiting the data to one version of each hull and engine combination. For example the 2015 Limited was chosen to represent all 2015+ 240 and 242 models. The result of which is this chart
![MaxFuelRange.png](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/63/63322-b69bf54c41697de29fdbd7280fb7af96.jpg)
From there I wanted to be able to provide an estimate of range in Gulf Stream crossing conditions on the way to Bimini. To do so I extrapolated fuel consumption based on a 2015+ 242 having a fuel range of 56 miles at 18 MPH. This is consistent with some needing fuel a few miles from Bimini Sands while others made it into port after the 58 mile crossing in 2017. Here is the extrapolated data. As a test this method predicted my 2007 SX230 to have approximately a 78 mile range under the same conditions where my observed range was 79 miles. Here is the result
![BiminiLikelyFuelRange.png](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/63/63321-40f0feeb319c40cdc47dcd5c734b47c0.jpg)
Furthermore I wanted to limit the data to just the boats in my group. I believe this explains why Chris24 (2014 212ss) and I (2007 SX230) had plenty of fuel while Betik (2011 SX240), Watergirl (2011 242 LS) and and @hobineros (2016 242 LSE) made it in on fumes.
![BiminiLikelyFuelRange.4models.png](https://jetboaters.nyc3.digitaloceanspaces.com/data/attachments/63/63324-1824b8d9b61bac46956839506ff0382a.jpg)
I have attached a spreadsheet with the raw data if you would like to add another model or improve upon the results.
