GTBRMC
 - Waukesha, WI
 - Boatless
 - SX
My understanding is that emissions were primary driver for MR-1 retirement.
Yep. Apparently they could not make them 4 star whatever to meet new emissions regs.My understanding is that emissions were primary driver for MR-1 retirement.
@Bruce I will need to build a sample excel and share with you to see how physible it is to collect the data.
@BigAbe75 trim tabs will be one the components and i should be able to tell you if the impact is significant or not. If it is then tell you impact ( reduction in range due to trip tabs). Best case scenario I should be able to see the impact by percent deployment. This last one is too granular and I doubt that people remember trim tab % deployed, but I will build it in the excel just in case. Who knows maybe 2018 becomes a laboratory and in 2019 the moment we exit port Everglades and see the wave height and determine the minimum speed needed to arrive safely in Bimini.
Once we have a reliable forecast I can build scenarios and prescriped actions.
Has anyone noticed increased fuel economy after a Lucky 13 cone and/or ribbon delete?
Oh, there is no question the L13 increases the pump efficiency, when properly tuned. Which could boil down to using the best spacer combination - NO impeller repitching or venturi nozzle boring is required unless you are really trying to squeeze every last bit of efficiency/speed.Has anyone noticed increased fuel economy after a Lucky 13 cone and/or ribbon delete?
I have done it all, and the effort IMO is not worth small gains over what you can achieve with the factory setup plus L13, especially in the 190s. Start with 2 or 3 spacers and adjust accordingly - reduce spacers if RPM is low, add spacers if RPM is high - one does not want to be hitting rev limiter at about 7,800.
I've had best results with it using OEM impellers.
We made it to Bimini Sands with almost 10gal in the tank (by my used gal gauge) w/no refueling at sea, in little under 5 hours. I think.@swatski I'm sure you told me already but how much fuel did you burn on the 2017 Bimini crossing?
Honestly, I could not give a number. I know the pump works more efficiently with properly tuned L13s as there is less cavitation/ventilation - generally associated with efficiency. Moreover, when running on one engine only - there is less cavitation with the L13 and the boat will actually plane and run way faster - and that is a pretty tough test. I think posted some data, but none of it is even semi-quantitative, more just a feel and general experience.How would you ballpark the fuel economy efficiency improvement with L13 vs stock?
That first graph has 2 purple lines. I suspect you're looking at the line for SX230.I’m sorry but is that graph showing over 190 miles out of a 242. I’ve never gotten over 2.5 mpg. On vacation I get .9. Lol.
