- Florida
- Other
- Other
This is the alternate bracket setup for Cobra Ultimate steering system on the late model nozzles. There are some for the 19 foot boats that have a keel. Those allow you to install the rudder attachment on the nozzle when you remove the rudder to access the side thrust unit during install.
This makes it convenient to simply install the 10 mm double ended bolt into the rudder attachment and then turn it up from the bottom through the nozzle boss and the new bracket , place a washer on and then a 10mm nut, tighten it all down and it's finished.
On the non rudder setups you install a 10 mm bolt from the bottom through the boss and then through the bracket, place the washer on and then the 10 mm nut tighten it all down and finished.
The original base would have been removed and the stand off from the nozzle would be installed with the other install for the side thruster.
So if you really need to play around with the new side thruster and you would not want to give up all the steering you get from Cobra jet system now you can. We did this to free up the bottom nozzle bolt to accommodate this.
However I would once again say the viper is a very good system for the 19 foot boats with the rudders, Steering at all speeds planning surface for better hole shot more stable hull in rough water, and slower planning speeds, with the fangs built in to one very simple to install system.
Also for the other setups the Mega Fangs are serious when it comes to enhancing the reverse steering, reverse thrust, the power steering and the regular steering for a very reasonable price and they mount on the existing side force stabilizer of the ultimate steering systems, but it's a free country and we always offer you the absolute most in available options to improve your boating so why change now.
alternate bracket for ultimate steering on new nozzles 001.JPG111 KB · Views: 88
alternate bracket for ultimate steering on new nozzles 002.JPG111.6 KB · Views: 85
alternate bracket for ultimate steering on new nozzles 003.JPG109.6 KB · Views: 85
alternate bracket for ultimate steering no keel setup 001.JPG105 KB · Views: 90
alternate bracket for ultimate steering no keel setup 002.JPG110.5 KB · Views: 84
alternate bracket for ultimate steering no keel setup 003.JPG111.2 KB · Views: 82
