- North Caldwell, NJ
@Mainah I love the idea. WOuld not worry about combustion. But would not cover the carpet, maybe UNDER the carpet.
I'm currently leaning towards pulling a "gmtech" - using large scraps of foam complemented with spray polyurethane. Not sure if I will do the water boxes as the opening in 240s is way smaller and I know from experience that reinstalling those (with extra padding) can be a giaagantic PIA.
If I love the foam pieces, down the road (when they start molding) I may consider replacing those by filling all the voids with polyurethane foam. But I'm not doing it right now as I may or may not be done with adding mods, so I don't want to block myself off.
@Mainah - since you are asking us to poke holes in the project plan - my only reservation/precaution would be with regards to that impending trip across the ocean. What usually happens on those trips, even in the smoothest of conditions, things get a bit rearranged and sorted out - some parts can break or move or get disconnected - so I would make sure you do not paint yourself into a corner with too much extra insulation, so to speak.
I know it is tempting to do everything while you have the boat "opened up"! But later this summer when you come back fro Bimini you will have all the installations sorted/verified - and then you can fix what needs to be fixed and seal it all up.
Anyway - just a thought.
Definitely watching your project(s) - so please please please keep posting!!!
