@swatski @Rhino @tabbibus @dnicholas47 @Hana Here is detailed video of the install. Dont mind the bad video I'm a little under the weather and I dont really do how to videos so be easy on me. This kit has now been installed for 7 months and has held up great.
@CraigAR Again, thanks for great info and video instructions, much appreciated!
I finally got to start on mine today! Ran into problems right away, lol.
Good thing I started testing as I was installing, found out I got a faulty control unit...
It's weird. The unit does not work when hooked up via the fused connector, which is how I want it installed.
I tested everything with the multimeter and confirmed I have continuity, correct voltages on all the wires leading inside the unit, it just wont turn on...
The weird part is that it works when plugged into the cig lighter (different plug/connector) albeit the "synch music" function does not work even then, it just turns the unit off.
I spent 3 hours troubleshooting, unsuccessfully:
But, having it plugged into the cig lighter I was able to test the strips and managed to mount one side of the boat:
Love the lights, this is a great kit.
Just need to figure out the module!
I waited too long for the install.. and the return window has passed but I'm hoping they will treat me well and replace the control unit with out too much hassle.
