vxooxv
- Harrisonburg, VA
- SX
I wonder if I could tap into my existing setup with wetsounds controller and RGB speakers?
Yessir. I have it hardwired and it works, except it comes on automatically when I turn the ignitions. So, I just have to turn it off with the dongle, no harm but annoying. I gave up on the customer service, they keep sending me new fuse blocks, not what I need... I have two control units doing the same thing. Will need to trouble shoot this when I'm back from vacation.So, like reported by others, everything test good with the cig light, hard wire it in, get nothing.
@swatski did you end up just splicing the barrel connector?
I also spliced the cigarette lighter and connected to a blue sea fuse box. Works great.So, like reported by others, everything test good with the cig light, hard wire it in, get nothing.
Otherwise all works well!
And now also including the "music/beat sync" - which is kind of a joke but fun nevertheless. This is how to turn it on, it took me a while to figure this out...
Yes, it's easy to open with some help with a small flat screwdriver. I ended up cutting the cig lighter wires and splicing a generic fuse holder with a 10A fuse into the positive, and connectign to a distribution block with cramped on o-ring connectors.How did you hard wire but keep the dongle intact? I was thinking you cut it off? Can you break open the barrel connector and get the wires after the switch?
In a word, yes. You can set it up for one color, any color, no strobe, no flicker, dimming is rudimentary but also works.OK @swatski and @CraigAR I've read all these, and all look great, but what I don't see is; do these lights always have to flash or "move" to the music or fade etc.? Is there anything in the remote, or the new Bluetooth remote that just puts on "blue" and stays that way, where I can adjust the intensity, but not go through all the colors and/or flash, fade, bump to music etc?
For example: What if I just want constant "white" light at the slip or dock to off-load everyone and gear, or just constant "blue" while having dinner at night?
