Judge
- Cape Coral, FL
- 275SD
I was having this same issue with batteries draining down. Does anyone else notice that the anchor light flashes about every 2 minutes? Guessing on the actual interval. Also my swim deck radio control backlight stays on when switches are left on. Both are pretty annoying. Might take it in for warranty with a few other items.
For the radio controls, are you in Float Mode with the key on?
I can see where it would be on in Float Mode but it should go out when you turn the key
For the anchor light, same question. Are you in Float Mode with the key on?
On the newer boats, the bilge pump apparently runs every two minutes with the key on. Wonder if you have a loose ground somewhere?
