Welcome and congrats on the boat!
First let’s talk about the stock / oem battery switch and it’s use. It’s a BEP marine battery switch with a DVSR (digital voltage sensing relay).
This switch is meant to leave both the start and house switches on all the time during operation and the DVSR keeps the start battery isolated. The DVSR closes the contact when either battery reaches 13.4 volts paralleling the start and house batteries, the little red is on when the DVSR has the switch closed and the start and house batteries are paralleled
and the DVSR opens the contact when the voltage reaches 12.8 volts breaking parallel or isolating the start and house batteries. Since you have LFP house batteries who’s resting voltage is 13.6 volts, you are going to need to reconfigure the DVSR for ignition or storage mode which is part of its design. Use the link below to see the operation sheet and the different operating modes.
Here is the spec sheet on the DVSR and it’s operating modes.
View and Download BEP DIGITAL VOLTAGE SENSITIVE RELAY instruction manual online.
manualmachine.com
Since the DVSR will activate with the LFP house batteries you have, the LFP batteries will start to discharge into your lead acid starter battery due to the higher voltage of the LFP batteries, thus the lead acid battery can overcharge. Doing the DVSR mod will alleviate that.
Since you have LFP house batteries you need to set up the DVSR so that it becomes active either when the engines are running or set it up to operate manually. I also have a LFP house battery and I have mine set up to operate manually from a rocker switch on the dash, I may go to the fuel pump hot set up this season, but so far I let the start battery come up to 14.4 volts before switching the DVSR on. Other members here have tapped onto one of the fuel pump hot wires so that the DVSR activates when that engine is running.
The advantage of having the little red wire tied to a fuel pump hot is that is a fire and forget and operates automatically through the day when ever the engine is on, this is how
@WiskyDan set his up.
@lazergeek set his up with a couple of relays so that which ever engine is on the DVSR operates. Either way this is a very simple modification to make, there are also guys who set the dvsr to operate when they turn on their batteries so that their batteries charge independently but that is for lead acid batteries. This is an elegant battery switch that does all the battery management for you, no having to remember to switch from 1&2 to 1 or 2 when you stop cruising… I have 563 hours on my boat now and the BEP marine battery switch has worked flawlessly.
As far as getting all of your accessory loads on the house battery goes you should probably get a service manual for your boat, there are single line wiring diagrams in the back of this manual, there has been some other members here who have moved accessory loads onto their house battery so that the starter battery is truly isolated with the dvsr is inactive. Here is my best guess on your set up, the sound system is controlled by the connext screen, but I’m going to guess that the sound system itself draws off of the house battery.
Another thing I think you will find very useful is a Victron Energy smart shunt to your house battery. This device measures voltage, current in and out of the battery, Ah’s & KWh’s used and state of charge-tge state of charge updates as the battery charges. It also has an auxiliary lead for watching the voltage on your start battery. This device will let you KNOW how much energy you have drawn out of your house battery and what remains, anything else is just a guess. It is configurable for any battery chemistry, size and voltage.
The SmartShunt is an all-in-one battery monitor, only without a display. Your phone acts as the display. The SmartShunt connects via Bluetooth to the...
www.victronenergy.com
It would be pretty easy to put the smart shunt on the start battery for a test to see how much power is being drawn from the start when it is on and powering the connext screen. That way you’ll know if you need to move any devices to the house battery. My guess is power draw will be negligible, but I could be wrong.
I know you have the NOCO charger and I’ve never seen a problem with them on this site, and its good you got the 10Ax3 as LFP batteries usually require 10A minimum charging current. Having said that I have moved to the Victron Energy IP67 chargers from my MinnKota 10A chargers, I think the IP67’s are superior as they can charge up to 25A which will cut your LFP battery charge time down by more than half. The IP67 chargers are highly configurable, can be used with any battery chemistry and size, the charging amp range is from 3A to 25A, have blutetooth connectivity so you can see what the chargers are doing and have done.
The Blue Smart IP67 Waterproof Charger is the new professional battery charger with built-in bluetooth. Find a Victron Energy dealer near you.
The Victron app is free and will work with all of Victrons devices.
You might want to read through this thread, thats my journey with LFP batteries and where I’m at now.
After having my boat for a second and full season, I found that can get about 10 miles out of my trolling motor battery, or about 6 hours of use at 1.8 mph, which is not enough for my average day of fishing which is 10-12 hours. So I was messing around with idea of replacing my trolling motor battery SLA batteries with lithium batteries, and possibly my house battery as well. I haven’t seen a thread detailing the math of LiFePo batteries, only that they are lighter, have more energy than SLA batteries, and most are super happy with them. Hopefully some of you will find the following...
What size LFP batter do you have in parallel?
Hope that answered all of your questions… if you need any help shoot up a flare and let us know.
P.S. If you use the sites search engine you will find that there is a ton information here that may solve any future questions you have.
