jetboater4life
- Rochester, MN 55901
- X
I ended up taking the kids to bounce world instead of finishing off the install. One more question though. Of the four wires shown in my picture with the ring terminals twisty tied. The two red 4 gauge wires are from the engines, no question on that. The other two are black 6 gauge wires and each run through a 20amp fuse that is screwed into the same area where I am installing the add a battery kit. Why would there be two coming from the helm? Is one for each ECM?and then which one carries the current for the helm accessories?
What confused me at first and prompted my initial question was that the wires were black. Because of the rats nest of wires with the bundled ground wires being right there too I didn't see that the 6 gauge black wires were fused (which indicates a power/positive wire "most of the time"). I'm in the process of fusing the ground wire from the ACR (per the manual), however I noticed @Rigger didn't do that. Blue seas calls for a 10 Amp fuse there.
