Can't find results: lower console compartment leak
Foustd10
Can someone point towards any post regarding fixing the center console leak in a fsh190?
I'm having little luck with the search results.
Thank you.
Is it coming from the anchor locker drain? Thats the most common place.
Thank you. Purchased used. Just tested this and it's leaking from there. Looking at the hole it seems to have been corrected already.
I'll redo the seals and try again.
Pressurized water can also get past the clean out port, and flow over the clean out tray cover while under way. Jetboatpilot.com sells a riser which moves the tray cover above the waterline caused from the back spray. You’ll also want to seal the edges around the large tray where it meets the hull. (The part the access cover fits into.
