Ok so during the busy season people asked me if I was going to do a special on my Ultimate steering since I was offering a discount on the new fangs.
I said I would do one when the slow season came around.
I was recently down to only a hand full of the fangs for the Ultimate steering and I was worried about running out of them again.
Now the good news, I just completed 40 more sets of the fangs and I have the inventory to support a sale on the Ultimate steering systems.
These are the most versatile patented steering systems you can put on your boat , These were designed to last and perform to your desired level of influence.
The patented adjustments allow you to choose the amount of steering they provide, so if you want your boat to handle better at all speeds slow and idle to top speeds, to handle like a sports car on a dry road, for better control at speed for water sports or just for a more comfortable feel . We realized years ago that the jet boats were fast becoming a family boat and more people were coming to this type of boat.
Over 15 years of making jet propelled watercraft handle like never before, you can even steer the boat while rapidly decelerating to avoid a collision, and in off power situations.
Our experience also taught us that making the steering adaptable to different users and various size boats was a BIG PLUS!!!
The Ultimate steering system features our patented multi function actuator that allows for you to set it in the UP position to raise your fins at planning speed if you desire or to set the fins to remain down at speed , It also allows you get to choose the depth and therefore the amount of influence they provide, with the ability to make changes if you desire, eliminating the need to purchase a different system if your needs change.
The fins are actually held down at speed by utilizing the thrust of the pump passing over the top of the actuator, a spring is added for backup in the event the engine stalls and for operating in reverse since the rear nozzle opening is closed in that position.
The same patented actuator can be set to capture the thrust to raise the fins at speed where the spring pulls the fins down for assisting with slow speed handling or off power handling should the engine turn off unexpectedly. And we never need to expose the actuator to the flow of water under the nozzle.
Our side force stabilizer was specifically designed to avoid having any cross bars or tie bars placed between the fins below the nozzle in the direct path of the water between the fins that could collect weeds or snag branches and damage the steering etc . In either setting the fins are NEVER " LOCKED DOWN " so if someone managed to strike a fixed object with a fin it would just flip up .
If you want a system that was designed to handle it's job without being destroyed during use and ruining you day on the water think about it, If the actuator ripped out from between the fins your day is over and now you need to get it repaired. How long will that take?
I actually make systems that were designed to be sacrificed in a collision, heck my original fins did that to save the pump and nozzle even my Magnum and Magnum A K systems have that in the event of a serious impact, But they still don't have flat or round bars positioned below the nozzle. So I just do not see that happening on my systems very often if at all.
We also carefully designed the actuator to stay away from the area below the nozzle between the fins to avoid producing any unwanted water spraying up behind the boat. And we paid close attention to unwanted oscillation caused by the system so we never had that either.
There are so many people on this web site that are using this system I would encourage you to ask members of this site who own similar boats how they like it.
I have always relied on feedback from real customers to promote my steering systems.
The system is actually easy to install and use , easy enough so that some members here have said it's so easy , even a caveman can do it.
I must say I believe the people here are certainly capable of operating a system as simple as mine, It reminds me of the saying "set it and forget it!"
I do my designs based on the K. I. S. S. principal , I make every effort to avoid over engineering.
I am the proud "sole owner" of 3 US patents , all pertaining to jet boat steering with a fourth one pending in the same category .
And let us not forget the Ultimate system is compatible with the fangs so you can upgrade if you so desire, It appears those are a big hit with the Admirals of the boat and I hear a lot from people who like the fangs for guest operators and teaching the kids to drive.
Now let us touch on the warranty, I strongly suggest you read warranties offered by others, we have all learned that lesson.
The law provides for implied warranties if they forgot a part, they owe it to you, if you get a defective part they owe you a replacement regardless of any written warranty. And the implied warranty also covers claims , if they claim it does or does not do something it needs to be accurate.
So we all have that. My warranty is on my web page it is called the 49 dollar repair or replace warranty, an example is if you accidently back your boat into a wall and damage your system you return it to me and as long as I am still making that system I will repair or replace the damaged parts of that unit for 49 dollars or less plus postage. Excluding intentional damage obviously! That is on ALL my systems by the way. And the nice part is you ONLY pay if you need it not incase you need it.
I also have the 30 day money back guarantee, not store credit, money back.
I do not cover return shipping because I pay the original shipping in the U S A Although most flat rate priority mail is very inexpensive.
So here is my sale price offer on the Ultimate systems not valid with other offers and subject to end with 12 hour notice or while supplies last.
The fangs will be 45 dollars for a single engine and 51 for a twin engine set only when ordered with the ULTIMATE STEERING SYSTEM !
Remember the twinset has one fang per nozzle and 4 locking tabs.
The Ultimate system will be $139 single and $278 for twin sets with free shipping in the U S A and you can still get the e z locks at the combo price of $26.50 for two or 14.95 for a single lock added to your order. Please place your order directly with me in an email to
jeff@cobrajetsteering.com or in a PM on this web page
This is not a group buy, no guessing or waiting to see what price you pay, you must be a member of this web site to participate the Ultimate system will fit all Yamaha jet boats with the exception of the 21 and 24 foot articulating keel boats.
I have a very special system for those applications called the Magnum A K system I also have special fangs for those systems, I have maintained the introductory price for the A K system at 324.25 that includes the extra tie rod and all the hardware you need plus an extra 39 dollars for the fangs, I don't want to leave you folks out so I am keeping the same low price for the system and I will throw in the fangs FREE during this sale.
Oh and the 4 tec people can also take advantage of the sale I posted on your sections All I need to tell you folks is it really does work for your boats just ask people who have them.
https://jetboaters.net/threads/4-tec-steering-info.11702/
Compatibility
The Ultimate system is compatible with the 19 foot boats including the newer models with the keel however the fangs are not designed for those 19 foot keel boats . Just a heads up on that!
You will also need to provide me with model and year of your boat and the state you are shipping this to when you place the order.
If you need more info on any of my products visit my web page
www.cobrajetsteering.com or my facebook page just search for cobra jet steering on the facebook . Remember Cobra jet steering puts you in control of your jet boat, The ULTIMATE SYSTEM puts YOU in CONTROL of the STEERING !
