[USERGROUP=9]@HELP[/USERGROUP] have a similar issue. Underway the port engine cut down to 2K and then quit. Put into neutral and will engage starter but not turn over. Limped back to dock and then tried the following:
Checked electrical, safety switches, and pulled sparkplug and have spark and smell fuel.
So there is fire and fuel an crank. So I feel like I ran through the checks but still nothing. Anyone got any ideas?
So yes there was spark and not a dirty plug. Replaced at 10 hours and 3 months later at 26 hours.
Will try to isolate further this morning.
Good news is since it's holiday weekend, I won't even try to go about the amateurs this weekend, but still unhappy.
Kids not wakeboarding this morning is less positive, but getting them ready for life.
Wow...I am amazed how less than 1% of boats made have experienced a timing chain issue, and just the rumor of has everyone jumping to this. It is rare and a remote possibility.
@RoughRider probable are the other things mentioned but not clarified. I have reread your posts twice now and they just are not clear from what you have said.
@swatski is probably correct here but I want you to clarify what you mean by "starter will engage but not turn over." If your starter tries to turn the motor, and it won't turn, how do you know it is trying to turn it? If you are saying you hear the solenoid click in the starter, but the engine does not turn, maybe the starter is not even turning the engine over. It could be a starter component issue too. Right out of the manual about engines that won't start...
WON'T TURN OVER (Nothing happens when you turn the key)
1.Fuse
2.Battery
3.Shift Lever
4.Starter Component
5.Cleanout Hatch
I don't think your situation falls under the following but repeating for completeness...
TURNS OVER BUT WON'T START (starter spins motor but motor won't fire off or run)
1.Kill Switch
2.Fuel
3.Fuel Tank-water or pressure
4.Spark Plugs or Caps
5.Crankcase filled with Water or Fuel
6.Fuel Filter clogged or water filled
If you hear anything that is indicating when you turn the key, that the start signal is going to the starter, but the engine does not turn, your kind of off the chart but the chart still guides you. For instance, it could be a starter component or a jammed impeller keeping the engine from turning, or it could be a battery issue. But based on what you said, the port engine only reduced to 2K rpm and quit, and assuming the starboard engine repeatedly starts, then we can rule out 2.Battery. Based on you saying the starter engages but won't turn over, we can rule out 1.Fuse, 3.Shift Lever, 5.Cleanout Hatch. What gets missed with the cleanout hatch is that it not only prevents the starter from engaging, but it also kills ignition, so the engine won't run and it won't turn, you don't get a starter signal...just nothing at all. So were back to starter component or something jammed in the impeller. I want to say also,
@Cobra Jet Steering LLC is as always, dead on...if you had a broken timing chain, the engine would spin just fine trying to start it...but it would spin without load or restriction, because the entire compression section is cut off from the drive train by the broken chain...although you may get some ugly noises too. Based on what you said
@RoughRider , it sounds to me like your pump is just jammed, and all you need to do is inspect and remove the offending object. But really, clarity on what you are actually saying is needed to further guide you. We really need to verify that your starter is engaging and that the engine isn't turning. I don't think your weekend is a total loss at this point, you could be on the water just after lunch!
