JWExperience
- Central New York
I installed a JL IB 10” under my starboard rear seat/storage and when I turn it up over 80%ish the entire sub and wall shake from the bass. It seems a little excessive and I’m concerned that I will get cracks forming in the gel coat. Is this anything to worry about?
I bought a spacer ring and sandwiched it on the inside of the wall to help spread out the load some but now I’m wondering if I need a larger slab the cover more surface area of the wall inside.
On a side note, my amp doesn’t have a “gain” dial, there’s three separate silver screws that say input “sensitivity.” I’m assuming they are gain? It’s a JL 700/5
I’ll have to start turning them to see where everything is set at for starters but it sounds pretty good currently.
