ken4motion
- 252SE
you will like it drives different from the previous hull design and the tower doesnt rattled like on the 2019Great thread! Following. Looking forward to your driving impressions. Meanwhile, I'm still under wraps here on Long Island...
Nice. Do you have a link for that?Did the exact same thing for my anchor locker. 3/8” thru hull. Thats how it should be from the factory. Not some plastic bs that dumps in the bilge.
I’ll look on my Amazon history if it was a bit longer I could have use the nut inside the locker,all I did fill the gap with 4200 put paper inside the Darin to keep the silicon from getting in it and tapped it wit a rubber malletNice. Do you have a link for that?
i believe i got the link from your post, but at least on my 252 not long enough for me to be able to use the nutthis was the one i got. it was long enough for me to put the nut inside. you want a 3/8" one. that is a direct replacement for the plastic stock one. no drilling necessary.
not really. 2 start batteries will do just as good a jobSo today, I installed a new onboard dual battery charger. The Noco Genius 10X2 fits perfectly in there. It's a beast! My observation is after hooking up the batteries is that I have two marine starting batteries installed new from dealer. Is not this supposed to have a marine deep cycle for the "house???"
View attachment 144797View attachment 144798
What fitting did you use? I am thinking of doing the bilge and pissers and with the issues I have heard about this drain I was thinking of maybe putting a fitting here also.
There’s a link to it a couple of posts up. 3/8 thru hull, lots of them on Amazon.What fitting did you use? I am thinking of doing the bilge and pissers and with the issues I have heard about this drain I was thinking of maybe putting a fitting here also.
Thanks, found it. I was going to go with the ADA Racing fitting for the bilge and bypass fittings. I'm wondering if a 45 or 90 degree fitting would work for the anchor drain to prevent water coming in. I need to get to the boat to look at this stuff.There’s a link to it a couple of posts up. 3/8 thru hull, lots of them on Amazon.
ADA racing makes nice pisser & bilge pump fittings but nothing flat & small enough for the anchor drain.
45 degrees you want the stream away from the boatThanks, found it. I was going to go with the ADA Racing fitting for the bilge and bypass fittings. I'm wondering if a 45 or 90 degree fitting would work for the anchor drain to prevent water coming in. I need to get to the boat to look at this stuff.
