Sarconen10
- VA
- 255XE
got it from jbpilot but i ordered it in december@jocolo21 did you get the black mooring cover from your dealer or from another source? Everything ive read on the forum is that no one has received the Yamaha mooring cover for the 25 footers yet. Any info is appreciated.
https://www.amazon.com/gp/product/B077BCKP7Y/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1do you have a part number for the big air? Picking up my. 252SE next week and wanted to order one as well. Thanks!
Your post caught my attention. I have a 212X that holds 4-5 gallons of water for some reason. The dealer said it is normal. When the forklift lifts the boat out of the water for storage, he tilts the boat slightly and a large amount of water comes out the drain ports. The bilge is working fine. Does water really come in the anchor locker thru hull and to the bilge? I would love to pinpoint the source of all this water stuck in the hull. It is not warm water, so I ruled out anything from the engine. When the boat is level, no water comes out of the drain plug area.Did the exact same thing for my anchor locker. 3/8” thru hull. Thats how it should be from the factory. Not some plastic bs that dumps in the bilge.
Definitely could be where your extra water is coming from. It's an easy enough and cheap enough fix to give it a try. The thru hull fitting and some 4200 or 5200 will only run you ~$20 and it only takes 30 minutes or less to change out. I wasn't getting a ton of water in my 252SE, but I still decided to change mine out last weekend.Your post caught my attention. I have a 212X that holds 4-5 gallons of water for some reason. The dealer said it is normal. When the forklift lifts the boat out of the water for storage, he tilts the boat slightly and a large amount of water comes out the drain ports. The bilge is working fine. Does water really come in the anchor locker thru hull and to the bilge? I would love to pinpoint the source of all this water stuck in the hull. It is not warm water, so I ruled out anything from the engine. When the boat is level, no water comes out of the drain plug area.
Wakeboard Tower | Wakeboard & Boat Towers | Big Air (bigairwaketowers.com)do you have a part number for the big air? Picking up my. 252SE next week and wanted to order one as well. Thanks!
the jl8.8 are 4ohms i got a jl800/8 pumping 200w per channel @ 4homs so each speaker is getting 200w, they sound purfect, then i got 2 jl 700/5 powering 8 jl speakers inside the boat the oem ws 10" sub and a 12" wetsound,bazooka .somehow the pads still stick. Yes it was a pita to wired.Why run to sets of speaker wires, instead of running each set parallel in 2 ohms? Running those wires sucked lol, my sticky pads at the stop no longer stick, did you have the same issue?
Link?
Link?
Just ordered.Speakersoxs.com
I had the expensive neoprene ones, they roted in less than a year, i belive this will last way longerJust ordered.
