bikerman5345
- 242 Limited S E-Series
I had to replace the Intake in the tunnel due to corrosion and very bad cavitation because of failed sealant. You can see in the pic Yamaha Fixed an issue so the sealant will not pull out any more. You can now fill the void and the mating surface with sealant and that void on the bottom will stop the sealant from being pulled out. On the old version it is just flat other than the groove in the transom piece so it would not take much to get the sealant to pop out. This also allows more selant to bridge that gap on the bottom side. On my Waverunner they have a rubber seal that fills this and the ride plate pinches it, then we also fill it with sealant to get rid of cavitation. So if you have bad cavitation and need to reseal the intake it may be worth upgrading to the new part.
