swatski
- North Caldwell, NJ
This has been driving me crazy. After installing SeaDek, no matter how much you try there are ugly snap-holes left (uncovered by the SeaDek). NOT a fault of JBP (manufacturer) at all! Rather, it is Yamaha's incredibly sloppy process of placing the carpet snaps - and many of the holes show spider cracks from factory!
On my last install I ended up with 10 or 11 (sic) "uncovered" holes like this one...
I have initially filled those in with 3M 5200 which does fine in terms of keeping the water out but discolors quickly (yellows).
So, finally I got to try fixing those holes properly.
Here is a hole filled with 5200 a year earlier - note yellowing of 5200:
To clean those holes up - using dremel tool:
To fill - the Spectrum (OEM) gel coat paste kit:
(gel coat matching published by @Ziess21 in https://jetboaters.net/threads/gelcoat-color-codes.14924/#post-257300)
To follow up - gel coat is curing now, after some (gentle) heat gun action will give it 24-48hrs to cure:
Next up - start sanding/buffing this weekend.
Hoping for "undetectable" results!
We'll see (TBA)
We'll see (TBA)
