dwall2181
- SX
Hi guys,
Racking my brain trying to stop a cavitation issue on a 2006 Yamaha SX210. On takeoff, I get the rpm's revving without thrust on my starboard side for maybe 3-5 seconds before the impeller bites and the boat rides normally from then on up in speed. This got a little better (less slippage) after changing the impeller and wear ring out but cavitation is still there just with less of a delay in thrust.
Also, the intake grate is missing (broke it) and it's back ordered from Yamaha. (been waiting 6 months)
I can hear a "pinging noise" when the impeller hits the wear ring when I run out of the water.
What should I try next to stop this cavitation?
I thought about changing the Jet Pump Bearings out next?
How do you know if it's the Jet Pump Bearing or the Intermediate Bearing?
Appreciate your insight!
