Yan Masse
- Trois-Rivieres, QC, Canada
- Scarab
- HO Impulse
I think it's lawyer time.
So sorry for you
So sorry for you
Maybe it can helpWho is the VP?
You only get the cover if you buy everything!@Slugger55 want to sell your trailer cover? figured I would ask...
Right?...
Working on these boats I have several other areas to check. Look at the Boeing area, the bow eye and horn are common. Also look at the docking lights on the 215 and 255. On the 195 you have to look up under the bow seat. The bow eye is easy but the horn you can't see without a mirror. You can reach up carefully with your hand and feel for wetness. On the 215 and 255 open the bow ladder and slide it out and everything is visible. Scary everything with a garden hose and look or feel for leaks. Everything in the boat drains to the bilge. Water moves a lot in these boats and will get warm just from being in the bilge that close to the engine that runs at 200+ deg. I have chased water leaks to find it coming from the bow area. Not saying this is the problem but easy way to check for yourself.
