How to get a set of spare keys for cheap
jetboater4life
Rochester, MN 55901
The dealer wanted $13.50 for a precut key and since I wanted 4 of them in addition to the 2 I already had (set for starting the boat, set hidden in the boat, set in the truck), I would have had to cough up $54 for four small keys. I went to a big box store and they couldn't make one. Then I went to a local locksmith and he made me 4 keys for $12. My locksmith had the correct type of blanks. Here is what he used.
http://mysecuritypro.com/yamahayh52keyblanks.aspx
The YH52 key blank is just a bit longer than my original factory keys, but they work just fine. Since they are backups it's a non issue for me.
I read on a different forum that Ace hardware carries a key that matches more closely in length. It is the SS4
http://mysecuritypro.com/SentrySS4KeyBlanks.aspx
One thing I will mention, and everyone should do this, is to write down the 3 digit key code on your keys, so that if you ever loose your original set you know that you can reorder them. Sometimes you can find originals on ebay for pretty cheap (mine wasn't available on ebay). Without that key code, you will have to call mother Yamaha with your Hull number or possibly a number off the engine to get the key number.
Here are some pictures of my YH52 spare keys.
Great tip, thanks for sharing!
Glassman
Yup, son in law's a locksmith. Couldn't pay for a key if I tried. He made several sets for everything we have.
Now if I can only figure out which goes to what.
Magic
Scottsdale, AZ
He must be quite talented.....seems he also found out how to make the keys to your daughter's heart as well! :winkingthumbsup"
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
Actually the 3 digit ignition code is also on the ignition if you ever loose your keys you can just pull that out and get another set made.......ask me how I know. :mad:
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
Actually I did get my keys back and didn't have to pull ignitions thanks to @mattschepker, but it was a close call. I gave my wife , @jcyamahariders wife , my keys for the very first time ever as we were finishing the day and she lays them on the trailer. Get home an hour and a half later and I ask where the boat keys were, here came the gasp......
jcyamahariders wife
Rosebud, MO
He should know better I always misplace everything from my cell phone to my purse. But as a good boating wife I always made sure I was on top of everything we were doing so it is not just on one person to remember everything. I slipped up but it ended on a happy note and a friend found both our keys :jawdrop:
TechRider
CT
Regal
Limited
Great tip. Just ordered 10 keys for $6.80. Now I have to make a trip to the hardware store to have them cut.
jetboater4life
Rochester, MN 55901
10 keys!!! Does everyone in the neighborhood get one? :)
TechRider
CT
Regal
Limited
It was cheaper to buy 10 keys then five keys. Now I can keep them everywhere lol
2.72 a key for four and .68 a key for 10. So ten it is :)
jetboater4life
Rochester, MN 55901
Gotcha, makes sense then.
Gym
Falmouth, MA (Cape Cod)
Hmmm, a 2013 AR240 huh? Maybe I should hang on to a set for ya...Just in case. :winkingthumbsup"
Be sure to double check your boat year to make sure you get the correct blanks,
my '07 took a YH 38 which can be found here http://mysecuritypro.com/yamahayh38keyblanks.aspx
the YH 38 has a slightly longer shoulder also but doesn't cause any functional issues, Be sure to call a locksmith first to make sure they have them in stock, it also cost me $3. a key
Unreal Yammi
Lexington, Ky.
There is a locksmith that I have used that can take a blank and a file, listen to the tumblers as he inserts the blank into the switch and cut the key with the file way quicker than him using his machine..he did it for my second set for another craft we own!
I now realize I need to get the second set for our 230. Thanks for this post!
Britboater
Punta Gorda FL, Abersoch UK
Yamaha keys are very basic, if you can buy the blanks any locksmith can cut in seconds on the machine, but I'm sure the locksmith could supply the key for a reasonable charge.
I sorted my old locksmith books out and remember Yamaha boat key blanks are motorbike keys from any manufacturer.
TugBoat
Seattle WA.
TugBoat
Seattle WA.
Will those key blanks also work for my 2015 Sx 190 key code 847?
acme-supply
Hello, I recently made extra keys using Ilco YM56 for a 2016 ar240. Fit was good and the length was the closet I could find.
