How to wash boat with no shore water
zpaul
LKN
252SE
So, I was spoiled having water at the dock in my previous marina.
Now I am on fresh water lake dock with shore power but no shore water. Boat on the HydroHoist lift that I absolutely love.
Now the problem is how do I wash the boat? I can technically bring fresh water from the house in some water cans but that is not very convenient. I can use lake water by getting some pump into the lake attach the hose and wash that way.
Saw some guy washing his boat with electric power washer but no clue how he supplied water to it.
What do you guys use in this situation?
Any pumps or handheld battery power washers with hoses dropped into lake?
I wash and wax mine real good at the beginning of the season at home. Then through the summer when it’s at the lake I’ll clean it with Boat Juice spray while on the lift. I’ll do it at the end of the week or weekend (whichever we were down for) to keep it from getting too dirty, and making it fairly quick to clean each time.
I know others use Hot Sauce similarly, and I’ll still use it when in the garage to remove water spots, but it left some hard to remove streaks when I used it in direct sunlight.
I think @biffdotorg did a video on that… it was a portable battery powered unit that would draw water from the lake.. I don’t think it cut the mustard though.
Found it here…
Since you have shore power I’d just get a RV style pump, they are diaphragm pumps and they will usually prime up to 6’ of lift from the water source. Get a high flow inlet side filter screen, I can help you source this if you need.
Get one that has 5 gallons per minute, these are usually in the 70psi range. You will have all the water you want with this set up.
Found it here…
I saw his video like a year ago looking for some gentle power washer. I think Dewalt will be my last resort. Neat gadget but a bit underpowered.
So RV pump just straight to the hose or like an add on to some lower psi electric power washer?
Was hoping that maybe I can find power washer that can pull the water from the lake with some filters added similar to dewalt but with a bit more power.
Or maybe I should use the RV pump with the hose and forget the power washer?
