Betik
 - Frisco, TX
 - SX
Well, there are approx. 10 orifices in the stern/bilge of my Yamaha that have leaked (or seeped in) water. That is not counting the pump tunnel - where missing factory sealant causes cavitation/ventilation requiring porting/sealing.
Thank you Easter bunny! Bawk bawk
No Justin took my green stuffI am one jelly bean your Easter bunny gave you that! Did it come packaged in that green grass stuff too?
 I am having troubles installing the hydrophase.  I contacted Justin. He advised me on taps.  Was going to go get my volt meter but the owner of the storage unit pulled up. He had one on him. Taps are fine, the fuse is fine, and all the plugs are fine.Do you mean the connectors? I (almost completely) destroyed/mangled one or two of those - as I wasn't sure if I should push or pull on some tabs...I am having troubles installing the hydrophase. I contacted Justin. He advised me on taps. Was going to go get my volt meter but the owner of the storage unit pulled up. He had one on him. Taps are fine, the fuse is fine, and all the plugs are fine. Probably going to send it back. @swatski @Ridesteady
I will add that I was also in a dark storage unit. Outside would not decide if it was going to rain. I am color blind as I stated to Justin " would you believe I am color blind?" His reply was yes.
Did the exact same thing... I couldn't get the one off and resorted to "gently" persuading with pliers...Do you mean the connectors? I (almost completely) destroyed/mangled one or two of those - as I wasn't sure if I should push or pull on some tabs...
Justin @Ridesteady replaced the ones I damaged when I sent the harnesses back for the VHF interference upgrade.
Did the exact same thing... I couldn't get the one off and resorted to "gently" persuading with pliers...View attachment 71052
Justin ( ) was kind enough to make the repair. Thanks!
Its not that hard . It took me 6 hours because I fumbled around in the boat and connected and reconnected multiple items to get the damn blue light on. Damn color blindness. If I would have my wife or one of my buddies there. 2 to 2 1/2 hours and I ziptied the shit out of stuff.Eeek... thanks for the tips. I'll be installing mine shortly, it's been on a shelf in my office since December. fingers crossed.
Although, wake boarding when my wife driving has been challenging and fun.
She likes to oscillate between 5mph and maybe 30, just to see me sink into the water before pulling me out again and making my arms a few inches longer.
Yeah, the connector on the accelerator position sensor on the starboard side has a clip that is designed in a way that it is up against the wall of the engine compartment (Yamaha design issue). It was a bizatch to remove... one because of the angle and 2 because the clip faces the wrong way. The port side was easy... if I was smart I probably could have pulled the APS off and then have easily removed it. I didn't even look into how the APS was mounted...Um I looked at that pic and thought that was one of my pics . I noticed the crack and was like shit I have to go to storage and look at that. Then I saw the mangled plug. That crack looks bad.
What about the crack in the fiberglass on the boat.Yeah, the connector on the accelerator position sensor on the starboard side has a clip that is designed in a way that it is up against the wall of the engine compartment (Yamaha design issue). It was a bizatch to remove... one because of the angle and 2 because the clip faces the wrong way. The port side was easy... if I was smart I probably could have pulled the APS off and then have easily removed it. I didn't even look into how the APS was mounted...
