veedubtek
- Punta Gorda, FL
- Scout
- Other
Crap, I clicked on this again.....she was looking over my shoulder.
How much of a drain on the battery she wants to know......see?
Can you tell us how you connected the power ?
I WAS gonna add I think @Bruce used "Wires" ......... but then I'ld be perceived as a SmartAss and we don't need any new rumors flyin' around here, now do we ? !Can you tell us how you connected the power ?
Its on my list. I am trying to find dimensions of the door lid thickness when closed and how far the drawer sticks out when open. My only available spot on the 212X that I can see is in the driver side console in the walk through area.
Can you show pictures of the wiring to see how it sets on the boat? Thanks!
@Bruce what gauge wire is running to the fridge? This is one of my must have mods for this summer and I am looking to mount it in the side of the driver console, did some measuring and it will just fit. I will be elevating it some so my folks don't have to bend over as much to get into it. What keeps the door closed? Don't want to cross a wake and have it slide open and I could not tell much from the manufacturers website.
I used 16 gauge wire which is soldered and shrink tubed to the factory wiring on the fridge with screw terminals soldered to the other end. The maximum draw is 3 amps and the length of the run is less than 6 feet so I could have used as small as 20 gauge wire. Based on the length of your run you may want to use 14 gauge wire but if you have 16 gauge wire on hand it will be fine.
The door has a latch that is released by pulling the handle. It will not open even in very rough waves.
What kind of structure do you have planned to support the elevated fridge? It can get quite heavy when filled.
Excellent. I ran a set of 8 gauge battery cables to a distribution block under the console to supply my amps and the future fridge. The run from the compressor to the block will be maybe 18" to allow removal etc. For support, the manual shows 3 holes on each side of the box for mounting and said nothing about supporting it underneath. What I was planning on building was a star board shelf somewhat in the shape of an H that will support it to the floor and of coarse whatever else I can come up with on mounting it. It will be well supported either way. I will trim the channel that the air dam door closes into to clear the drawer, then C notch the door panel so it clear the drawer as well and still allow the air dam to be closed.
