- Panama City, Fl
- Other
@M@_ we have not tested but know we can make it work. Can you send pictures? Better yet are you near Panama City?
@ptwb in neutral the lateral thrusters are not really going to help. There is not enough flow going through the pump to give them much influence.
I will try to test with a rudderless 24 footer next week.
Maybe sending the correct drill bit and tap for the earlier models would help with the install.
We also thought about making a special bracket that mounts to the bottom corner pump Bolt instead of having to drill and tap.
That's awesome!!Hey guys, this morning I was able to get some new footage since the weather was permitting. We have produced the first of many docking maneuver videos that will help you to see the advantages of installing a Lateral Thruster on your Yamaha Jet Boat.
Lateral Thruster Back 90 Degrees Towards Dock
@TheGreekTitan actually no, the twin engine version does the same thing. Select the side of the boat that you want to push and use that throttle lever. That is how I've taught myself to use the lateral thrusters on a twin engine boat. If I want to push the stern to the left I use the starboard motor to push the boat left. I leave the port motor in neutral to minimize rearward crawl. When I want to push the stern to the right I simply use the port motor to PUSH the stern to the right. In this way a twin engine user has more options when docking than a single engine user does.
@blacksapphirez we have a close friend who works for Yamaha and we've shown him. I'm sure if Yamaha is interested there will be some conversation.
Thank you also! We think this is going to sell boats as well as our products!
