BigAbe75
- Litchfield, IL
- X
Good detailed reply. Thanks!No we've been testing as though we're using the most common setup out there which is no factory bags at all and then adding our ballast system to the boat to show how easy it can be to get a great wave without having to run all that plumbing and take up all that valuable real estate.
We've tested with the standard ballast and the result was not that great. It just does not put the weight nearly far enough back to make a great wave. If you had a 212X and wanted to use the factory ballast as an accent to the steel shot that would probably save you some money, but nothing we've tested gives us the results that the 600 lb bag on the lower swim platform does. It is super dense, concentrated weight all the way aft as far as you can take it and as low as you can take it. It acts like a lever on the stern and pulls the transom down into the water making a huge wave perfect for pushing big riders!
If you want to use the center bag you can certainly do that, it will likely take the place of the weight we're putting in the bow, but bear in mind that too much weight in the bow causes the wave pocket to get longer but the height is diminished. For this reason we've really grown fond of the steel shot bags. You can toss bags around quickly and find the perfect setup easily. Once you've discovered the best setup its easy to write down exactly how many bags you have and where. Your results are easily duplicated.
What do you expect to see on the 24’ boats?
