- Panama City, Fl
- Other
Yeah there's alot of detail in this one.An hour install video... wont he watching it in truck
Thrust Vector Wake Install Video: If you are planning on doing your installation you will want to watch this video and get familiar with the tools needed to do the install correctly. Allow for 5 hours cure time for the epoxy on the up stops. If you install in the morning, go boating in the afternoon!
By relocating the anode on a bracket it is no longer protecting the pump as it is supposed to, you will only be protecting the bracket it is mounted to. To be effective the anode must be mounted to the metal that you want to protect, in this case the pump.
SHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH damn it, don't give away secrets
Ohhhhh boy. This would have been nice to know ahead of time. I only boat in fresh water so maybe not as much of an issue as salt. But still. If this causes possible damage to the pumps then it’s not as good as we hoped. Maybe Will can shed some more light on this.By relocating the anode on a bracket it is no longer protecting the pump as it is supposed to, you will only be protecting the bracket it is mounted to. To be effective the anode must be mounted to the metal that you want to protect, in this case the pump.
Due to time constraints I won't be able to do a removal video, but you will not reuse any of the parts from the original Thrust Vector kit during the Thrust Vector Wake install. Let us know if you experience any trouble removing the old bolts from your Thrust Vector kit, particularly the mount bolts. Older kits that had the spring tensioner will require a pair of vice grip pliers to hold the tensioner steady and the proper allen wrench to remove the allen head screw on the end. I think it was 5mm at one point and earlier it was a bit smaller.Will, as many (most) of us have previous Thrust Vectors, could you provide a similar install video showing the full removal and replacement? Curious if there different procedures or ‘saved’ parts?
We're being advised that there will be no issues with the anode relocate bracket. Newer style brackets will be aluminum and some of our older versions will be stainless. Both will work well but if you prefer aluminum you can contact us to special request.Ohhhhh boy. This would have been nice to know ahead of time. I only boat in fresh water so maybe not as much of an issue as salt. But still. If this causes possible damage to the pumps then it’s not as good as we hoped. Maybe Will can shed some more light on this.
More than likely to keep things moving I'll probably make my own bracket out of 5052 Alum at the shop, I would prefer that over steel and stainless for this application...but good to know there shouldn't be any adverse effects.We're being advised that there will be no issues with the anode relocate bracket. Newer style brackets will be aluminum and some of our older versions will be stainless. Both will work well but if you prefer aluminum you can contact us to special request.
We're getting aluminum brackets made as we speak so if you prefer just ask for aluminum in your kit so you don't have to make the part.More than likely to keep things moving I'll probably make my own bracket out of 5052 Alum at the shop, I would prefer that over steel and stainless for this application...but good to know there shouldn't be any adverse effects.
Hey guys and gals, we are preparing to ship product and before we do we wanted to get as much new info to you as we could. You really can't imagine all the work that is going on right now to ensure that everything ships on time and with quality. We're producing new video content to update you on new advancements that have been ongoing and that will make it into kits preparing to ship on the 21st(keep your fingers crossed on that date).
This is the first of several videos that we are debuting today. Its a new breakthrough in the Thrust Vector Wake product which was discovered only weeks ago. It is giving us incredible results and the gorgeous wave that you've been seeing in all our twin engine videos has been, in part, created with the help of this breakthrough component! We're calling it JetWash Deflector. Here is a video introduction to the JetWash Deflector.
If you can turn on the power and move the levers forward while the engines are off you can then turn the power back off with the nozzles left in the up position. Worst case scenario you can disconnect the cable from the reverse hood as shown in the video. the reverse hood has to come off anyway so you'll want to familiarize yourself with this step.@JetBoatPilot how do you lift the bucket on an E series? (For use of the upstop measuring tool). Can you still push it by hand? Moving the throttle isn’t going to do anything, correct?
Was this extra component used in the earlier demo videos?Hey guys and gals, we are preparing to ship product and before we do we wanted to get as much new info to you as we could. You really can't imagine all the work that is going on right now to ensure that everything ships on time and with quality. We're producing new video content to update you on new advancements that have been ongoing and that will make it into kits preparing to ship on the 21st(keep your fingers crossed on that date).
