Lectrotab Trim Tabs
BigAbe75
Litchfield, IL
Hi Jetboaters,
Semi Noob here. I just discovered this group buy and want to get in on it. But I have a few questions. I have a Wake Wedge mounted on the left side of my hull on my 2017 242X. (My boat is still in storage so I can’t go look at it.) My primary question is will these the top left side trim tab actuations install without conflict with the wake gate operation? It looks like the left side might be close to being in conflict. And if so might I move the top mount location so they don’t conflict? Thanks in advance for your help. See the pics below for perspective.
Per @swatski reports, yes this design works fine with the WakeWedge. Here’s his thread. It’s a good read.
zipper
Boston Whaler
Hi Jetboaters,
I know this boat very well...20200329_101148.jpg It is a 2007, different hull/transom than your boat. I do not use a wake wedge but others with your model year should have an answer for you.
HughSethner
I know this boat very well...View attachment 114697 It is a 2007, different hull/transom than your boat. I do not use a wake wedge but others with your model year should have an answer for you.
Thank you Zipper! Being Sunday I emailed my order in. Do you know if that was the correct way to get my order in? I did not see a group buy form or registration? Thanks!
zipper
Boston Whaler
Weeb
Denver NC 28037
I would give them a call today to make sure it gets processed right. All the info is under the group buy thread
Bonzaibloomfield
I'm new to this. Does anyone have an invoice for a kit that fits 2007 ar230?
LayneG
I have a set of brand new trim tabs that was for my ar240 I'm going to list.
tdonoughue
The Woodlands, TX 77381
@Bonzaibloomfield , I don't, but if you call them, they are very helpful and will work with you to get you the right setup and a quote for it. Highly recommend that.
zipper
Boston Whaler
Sxviperman1
Scarab
215 ID
Anyone put these on a scarab 215?
tdonoughue
I have not, but I would bet if you called them they will be able to tell you if they have done one of those boats before...
