305SX230
- SX
Hi everyone, I could use some advice. I have an 04 SX230 with the MR1 engines. About 2 months back, I took the boat out, and the starboard motor overheated. I looked over, and water was coming out of both of the spouts at the same rate. When I got home, I ran it on the hole, and it would not overheat. I clamped off the hose headed into the motor, and connected the hose to flush the intake. I ran it again, and it still overheated. I pulled the thermostat and found it was in bad shape. I replaced the thermostat and cleaned the housing, but it's still overheating. I also ran the YSD 2.0 software, and all sensors read as functional. I'm I missing something? Before I pull the motor out and check all the water Paths and valves, can you guys think of anything? All most forgot to mention it also does not overheated if idling in a body of water.
