ToddW850
- Destin, Florida
- 242X E-Series
Very unfortunate. Can you try this? Put something under the trailer jack in the front and jack the front of the trailer up as much as possible. If your gas tank is still full of fuel, I'm wanting you to look around the top of the tank while it's jacked up. Look specifically around the vent hose connection and the gaskets around the top of the fuel pumps. Actually, just look at EVERYTHING connected to see if you spot a leak. Even if it is just dripping. Oh, and make sure you inspect the tank before you jack it up and make sure it is clean and dry, so you can spot any leaks easier. My money is here for a leak.
