Need larger bimini or addon aft bimini for 2021 AR210 with forward swept tower
Shadowrider
Does anyone know what companies can make/or has and existing rear bimini that will easily mount on the 2021 AR210? My existing OEM bimini is to short to provide any meaningful shade to the rear portion of the boat. I'm in Tampa FL and have called over 10 local bimini shops with only 1 actually returning my calls. Thanks for any suggestions.
Idk how long the factory one is - this one is 72"
thanks for the reply, just checked and none of the one's listed look like my Yamaha OEM tower. Did you see my pic of the boat?
Check out this thread:
I have one of those and use it often. Adds a ton of shade to either the bow or stern seating, is relatively easy to put up and stows very neatly. Makes a great beach umbrella as well :D
I have the same year & boat as OP and agree the bimini is on the small side. I have the taylor-made anchor shade and like that I can use it in the bow or the stern. It lives in the starboard rear compartment, setup takes about 2 mins with two people. You cannot, however, use it while underway or if it’s really windy.
Sewlong can make them for you https://sewlong.com/. I’ve seen some guys have them made for their wake boats.
