- Lake Ray Roberts, Texas
- Boatless
- NA
- Other
- NA
Mine r not cracked that bad but I am missing a bolt30 miles from the dealer i had all 5 balanced. It didn't help much if at all. See above.
View attachment 23680 View attachment 23681
You of all people shouldn't need to pad your post count like this. . . . . : )
ForView attachment 24106 those of you with shorelanders that tow smooth how much tongue weight do you have or can you put up pics of your trailer setup.
View attachment 24574 View attachment 24575 View attachment 24576 My trailer fenders broke too. I went back to dealer and shorelander replaced broken parts. I think it's a poor design on their part as the shackle bolt goes thru fender bracket. As it works (trailer going over bumps) the bracket turns with bolt causing stress in the cheap plastic and alum tread plate. The dealer said they never seen this problem before. Dealer just replaced parts and I expect it to break again.
I noticed that the left fender was vibrating when towing to Ft. Lauderdale, so I took a closer look at it today. My new 2015 galvanized trailer lost 2 bolts and 3 nuts/washers on the left fender. I replaced the missing parts with stainless parts. I went with nylon-sleeved lock nuts.anyone else with a 2015 24' having issues with thier trailer? Last week I noticed while gassing up that the fender bolts were very loose. I tightened them all up. This week it seemed that the fender was rattling on the highway, after getting home I noticed another bolt gone altogether. You may want to check your trailer for loose bolts!!
