the MfM
- Other
- Other
- Other
There’s ohm specs for the cdi box in the service manual. But these are pretty simple systems and not much in there that would cause the boat to run rough and then die...There is no ECU black box. Magnets Falling off aren’t a common problem (that’s more of a sportjet issue). though the OP could pull the stator cover and make sure Metal bits aren’t floating around.Ah, we have @the MfM in the house. Finally, an expert on these engines...
Do you know a diagnostic procedure for the stator?
I’d be looking at compression. After testing spark.
And of course look at the battery/starter cables. And make sure all the connections are clean and tight. Ecspecially the grounds.
