Jaycav
- Cleveland,OK
- X
We been in the water since Thursday. Got about 1/4 or so left on the second fill up
Went out with 3 coworkers Thursday after work, kneebarded, wakeboarded and cruised, first thing the DW asks when I got home was "how much gas did you use?", not hi, how was it, have fun, all go good?I was on the water 3 days this weekend and went through 25gal of fuel. I thought I used a lot. WOW!
@Lilman573 Not to change topics but I have had similar overheats on both of my engines and I always flushed them. I do not attribute the overheats to salt or corrosion. The cylinder water jackets were filled hardened sediment, the worst of it was by cylinder#1. It was like concrete. I had to chip it out. I would like your explanation of what you call "bad design." I have documented my experience at Overheat Prevention. Are the photos at the beginning of the thread at all similar to what you observed? I will appreciate your feedback. Thanks in advance!Unfortunately, my MR-1 still ran, except for showing overheat, when it was removed. There was so much salt and corrosion in it from not being properly flushed (coupled with a bad design) the block actually had a piece break off over the winter. The cooling jacket was filled. Motor #2 had the head removed, cleaned and the block cooling jacket was cleaned as well. I now use salt away with every flush. See how long that helps!
@Lilman573 Did it look anything like the pictures in this link: Overheat Prevention?@WREKS , I have pictures of what the second block looked like. I have yet to tare into the first, but can tell you the front was completely blocked with salt/corrosion. From what i can tell, the block progressively filled up and the hard sediment is salt and the motor actually corroding and creating that hardened calcification.
This is an issue that is pretty well known in this motor. I am not sure if it is a combination of not having a large enough flush tube, how the motor is angled, or why it wouldn't be able to fully flush the block.
@Russell , not really sure but i do see the OP's motor has some degree of scale as well...Do you guys think that this crud is lime? Maybe a Lime-a-way flush is in order to keep the jackets flowing freely. Safer yet would be a vinegar flush.
In my overheat thread Overheat Prevention there is a photo of the some of the debris that I chiseled out. It probably is a combination of compounds, but I think, mostly sand. When it dries it becomes a granular. I tried soaking the water jackets in vinegar and Dawn for a half day to break it up. It did not seem to have any effect.Do you guys think that this crud is lime? Maybe a Lime-a-way flush is in order to keep the jackets flowing freely. Safer yet would be a vinegar flush.
Tried a few spray on things, even carb cleaner, on the exhaust manifold to see if anything helped. Mechanical removal was really the only thing that helped, which is why I was pretty sure it was aluminum oxide. Its actually the aluminum oxidizing and basically hardening in the passages.In my overheat thread Overheat Prevention there is a photo of the some of the debris that I chiseled out. It probably is a combination of compounds, but I think, mostly sand. When it dries it becomes a granular. I tried soaking the water jackets in vinegar and Dawn for a half day to break it up. It did not seem to have any effect.
My engine was freshwater only with around 10 hrs on it@Russell , not really sure but i do see the OP's motor has some degree of scale as well...
I am trying to use saltaway after each run this season. I will see how that goes.
Well, I'm at about 8. I better get to rebuilding that spare motor. I also chose the SBT standard so I plan on using it hard to prove it through the warranty period. Hoping to get 20-30 hours on it by the end of the season. I'll have the motor rebuilt over the winter and then if I need to I already have a spare.My engine was freshwater only with around 10 hrs on it
It's kinda like going to the casino. You only hear the one side of when someone wins big. Never when they loose or how much they spent to win. With SBT or any aftermarket parts you always hear the one side & it happens to be the losing side. If they built junk and most of their engines that went out the door blew up they would be out of business. There is going to be a failure rate with anything, it's just that we hear a majority of the SBT failures.I have an sbt engine in my 1500 stx jetski and it has been good. I build my own car engines, rebuild several types old and new engines. The quality on the sbt looked pretty good to me. We only hear the bad stories. Pre start lubrication and proper break in are important for example.
