84rzv500r
- Lower Keys MM29
nope its CorrosionX heavy duty... Salt water/salt air is your enemy... it stays kinda sticky , cleans up easy with brake clean... I have a plethora of anticorrosion and lube tricks... 80W-90 in the steering and shifter cables, TefGel in the bolts/connections up top, marine anti seize on everything below the waterline, permatex anti sieze on engine, CRC heavy duty corrosion inhibitor on exposed engines and all the aluminum under water and I use 316 stainless everywhere.. superlube PTFE spray and dielectric.. and a good WATERPROOF marine EP grease I lube the exposed cables and pump nozzels and such once a month with grease and CRC, your hands might dirty bout it all comes apart and doesn't corrode.. I use my boat nearly every day in the salt water... so maintenance stacks up... oil changes every couple months...
