84rzv500r
- Lower Keys MM29
PO hacked up the boat harness a bit... all straightened out... Will double check the keyswitch and power and integrate the boat harness to the engine harness,... and get this if the harness wasn't hacked up a bit you could have just plugged the two harnesses together !!! and you get start/stop, the only different presentation is the G & B for the tachs have plug connectors not sumitomos on them and you have to provide keyswitch 12V to light the ECU and Main relay as the 2 strokes in the AR210 didnt have this
I'll just splice on new connectors w/ correct lengths to dress out the harness.
Adjusted stbd TPS to 0.547~0.562V and both Idles to ~1600 RPM...
Dressed off the fuel pump wires.
Oil pressure on each engine looks good ~22PSI at 1600 RPM and ~55 PSI at ~5000 RPM warm...
These engines are SOOOOOOOO much smoother and quieter than 2 strokes... and they start instantly
Fuel press sending units arrived yesterday but the stewart-warners are on backorder
once i get the key switches in im gonna call the repower complete... I have an idea for using the guts of the MFD to light the TEMP, OIL, and SEL lamps on the tach...
