84rzv500r
- Lower Keys MM29
cleaned up some more wiring, prepped the 18 pin connector for surgery... got tired of wiring after a few hours and decided to pop in the Auto/Manual halon system... Mounted the cylinder between the engines on the forward wall... ran the pull cable and used the old choke cable bracket I made for the system charged indicator light and manual pull handle... space it tight bit I got all the placards in as well with some adaptation... also started work on the console dry storage hatches... gonna pull a mold of the top and bottom of the hatches and make them out of fiberglass the just get old and shatter... I had a perfect one just shatter today I have i good one left out of 4... also put in the filler plates for the unused gauge holes... and hooked up the oil pressure tubing...
