84rzv500r
- Lower Keys MM29
I can tell you that these two harnesses are the same... and have the same pin anomalies... i have a FXHO harness comin this week... and now all but pin 32 on the ecu agree with the SKI harness... I need to pull out the two other harness that I have and take a look... not sure what the ECU uses to determine run. if you ground the white to the black.. the ECU clearly sees that the stop switch is on however it still thinks the engine is running at 0 rpm...
